Twin 61mm, A/R .63 too small on a 408?
i had a .81 or .83 or .86 exhaust housing on mine. It was a honda civic 1.8 with a 5 bolt down pipe. my 38mm waste gate did fine at 10lbs of boost, it was turned up to 20lbs but it was fine on 10lbs without the mbc. I would try somewhere in the .8x a/r its almost the best of booth worlds. quick spool with decent power
Assuming these would be low mounted, a small amount of additional heat wouldn't be too bad. A big A/R on a 61 could be better depending on power requirements.
As for E85... since I do DD this thing, doesn't it get crappy gas mileage?
I know...
The PTK done right like myself, Nick, Kevin and others, is fine for running as hard as you can on the street and the strip. I run it a tad harder..
Nick and I are talking about some ideas and some of his many new options![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
![Icon Rolleyes](https://ls1tech.com/forums/images/smilies2/icon_rolleyes.gif)
E85 would cause higher gas mileage,i think its about 30% or something. but think of the benifits. more power form the same boost. no need for a meth system any more. or keep the meth and run super cool intake temps...
what size and style turbos are the TTi guys using??
Chris.
