APS Stage 2 Kit
Old Aug 28, 2008 | 09:50 PM
wildta's Avatar
Default APS Stage 2 Kit
Just wondering if anyone else on here has the stage 2 kit yet, besides me!
If so anyone started there build yet ?
Thanks Warren
Old Sep 2, 2008 | 09:33 PM
jsds500's Avatar
I have mine. waiting on my lsx block to get back from the machine shop.
Old Sep 2, 2008 | 09:46 PM
LS1 SPEED's Avatar
We should have a WS6 on the rollers sometime within the next 7-10 days.
408 w/AFR 225's
Old Sep 2, 2008 | 10:02 PM
Mike101's Avatar
408 w/AFR 225's
sweet def cant wait to see this! please keep us updated
Old Sep 3, 2008 | 12:23 AM
wildta's Avatar
408 w/AFR 225's
I wanna go 427 myself, why 408 for you guys ?
JSDS 500 what block size you going with ?
Old Sep 3, 2008 | 07:59 AM
jsds500's Avatar
I am building a 440ci with ls7 heads.
Old Sep 4, 2008 | 12:18 PM
99 black ss sj's Avatar
408 w/AFR 225's
keep ask updated, im really curious about this setup its really similar to mine, whats the spec on the cam?
Old Sep 4, 2008 | 02:52 PM
LS1 SPEED's Avatar
We hope to be on the dyno Tuesday afternoon. We will post an update with specs when complete.
Old Sep 5, 2008 | 01:29 AM
wildta's Avatar
Why the 408 and not bigger?
warren
Old Sep 5, 2008 | 03:04 AM
james562's Avatar
warren
Probably price. The 408 should be plenty and can be had for under $4000
Old Sep 11, 2008 | 10:00 PM
qqwqeqwrqwqtq's Avatar
Update on the 408 APS car. Made 634rwhp @ 11psi and 809rwhp @ 18psi through a T400.
We will dial it back a bit for now as the 60lb injectors were at 106% DC with 73.5psi base pressure.
Old Sep 12, 2008 | 10:06 AM
MY99TAWS6's Avatar
Pretty good numbers but would have thought they would have been higher with the bigger turbos at 18psi. Now turbo 400 converters have no lock up?? so would that also make it read quite a bit lower than stay a converter that locks in a 4l80e? any estimates on how much lower it would be?
What intake manifold were you running? What compression ratio?Was this pump gas or alc injection.What afr and timing? I would assume secret cam specs?
Looks like the bigger turbos have no trouble putting out 18psi without any collapsing duct problems?
How about spool up..where does the boost start to come in at. I could still trade up for the bigger turbos as haven't even installed mine yet.
Old Sep 12, 2008 | 10:09 AM
TNTramair's Avatar
nice numbers!!!
Old Sep 12, 2008 | 10:21 AM
MY99TAWS6's Avatar
So that would be like 91 psi total fuel pressure with a boost referenced regulator. What fuel system does the car have?
Old Sep 12, 2008 | 04:00 PM
DanDan's Avatar
Did the ducts hold the 18lbs?
Old Sep 12, 2008 | 09:46 PM
The torque converter was not locked, and yes that means a signifigantly lower number to the rear tires.
LS6 intake manifold, around 9-1 compression (I'll find out exactly), Through Borla exhaust.
100 octane, 11.8-12.0 a/f ratio. 15 deg@peak tq 17 deg@peak hp. Cam is 232/232 113lsa.
Can't give you an accurate estimate of turbo response with the unlocked converter as it flashes while it's building boost. Responds quickly with no perceptible lag.
Boost held perfectly flat up to 7k rpm with the EB2 which indicates the ducts are not a restriction. I don't imagine they will collapse as they are rather beefcake
Old Sep 12, 2008 | 09:49 PM
nuclearxp's Avatar
11.8-12.0 is a tad lean for that much boost, even with the semi-mild timing on race gas?
Old Sep 12, 2008 | 10:04 PM
MY99TAWS6's Avatar
Anyone know approx how much lower number do to an unlocked converter?are we talking 50 rwhp here or 20 or 100 at this power level?
Anyway good to see the boost was steady and looks like no problems with the bigger turbos and their intake tubes. Now we need someone to test the improved tubes on the smaller turbos at high boost.
Old Sep 12, 2008 | 10:14 PM
Is that a question or a statement? Regardless, the answer is no.
Old Sep 12, 2008 | 10:15 PM
If you want a guess I would say a locked converter could be 50-70 more at the tires.
