ceramic beads=turbo death???
Old Aug 30, 2008 | 02:05 PM
DanZ28's Avatar
Originally Posted by Photochop
Could be...I'm not real sure. I had my headers/crossover sandblasted and recoated silver. I'm not sure what the stuff is, but they were white and less than 1/8" in diameter. There were 3 that I saw stuck in between the primary tubes meeting the collector. We tried to blow it out with air, poke at it, etc and couldn't get it out. So far so good...
I had about 6-7 of those stuck in the same place on both headers, they were about the size of a BB. I manged to get all mine out with a screwdiver and a curved scribe, took about an hour or so, PITA.
Dan
Old Aug 30, 2008 | 02:31 PM
Photochop's Avatar
So are these things potentially detrimental to turbo/engine life? Or do they break down/stay put? Now I'm concerned and thinking about taking my stuff apart to get them out if it could cause potential serious damage...
Old Aug 30, 2008 | 02:57 PM
DanZ28's Avatar
They may stay put, but who know's for how long. If one does come out, could take out the turbo and if it goes through and to the engine, well!
Dan
Old Aug 30, 2008 | 04:58 PM
presto_z's Avatar
Dan
i dont think the bead could physically make it into the engine. the exhaust does not go into the motor, it just spins the impeller. im worried about the impeller being chipped, shattered, or thrown off of balance. causing the turbo to come apart and into the motor
Old Aug 30, 2008 | 05:25 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Just smash them out of there or get an air tool with a really long extension.
Old Aug 30, 2008 | 05:35 PM
bboyferal's Avatar
Presto, are you the one that had sent something to a "coater" that didn't call back, went on some trip, and then left your pipes to be picked up outside his shop?
If not please disregard!
Also, do you ever go to any meets in SFL because I don't think I've ever seen your car?
Old Aug 30, 2008 | 06:50 PM
presto_z's Avatar
yes thats unfortunatly me....
i use to go to local car shows, but i havent in awhile.. im in southwest florida between sarasota and ft. myers, so south florida is kind of far. 3-4hrs away from miami
Old Aug 30, 2008 | 09:45 PM
qqwqeqwrqwqtq's Avatar
Any pics? I've built plenty of headers and I can't picture how a porcelain/ceramic bead could get stuck in one.
Old Aug 31, 2008 | 01:38 PM
presto_z's Avatar
they are stuck where the primaries come into the collector. i will try and get a picture up later on today
Old Aug 31, 2008 | 07:37 PM
Photochop's Avatar
^Exact same place mine were/are. I didnt get any pics of it though when the car was down.
Old Sep 1, 2008 | 01:52 PM
DanZ28's Avatar
Thats true, it would have to suck it in through the exhaust port, my bad!
Those beads are now coated and pretty solid though, air tool does nothing and you cant squeeze them. If one hit the blades, I would think it would do dammage.
Jim, if you look back up the header threw the collector, there are those crevices up there where the primaries are welded to the collector and thats where they get lodged. Some of mine where loose enough that when I hit it on the ground a little, some fell out on their own.
