Rear Mount Folks, Some ??'s
Old Sep 2, 2008 | 09:37 AM
T61M^3's Avatar
Originally Posted by ZL1Killa
first of all, with JUST the STS piping you don't lose any boost, if you do it is very little.
you usually lose 2-3psi through an intercooler like you said.
If the pressure loss is that great, that core/end tank design is a giant
Old Sep 2, 2008 | 10:17 AM
ZL1Killa's Avatar
i'm speaking loosely here.
I'm actually losing about 1.5psi TOPS , seeing ~5.5psi with a 7psi spring
Old Sep 2, 2008 | 11:44 AM
jeffboy757's Avatar
if you run an intercooler, you goota run your boost reference for your wastegate from your throttle body, that way you dont have the pressure drop from the intercooler, i have a normal sized intercooler, 24 x 12 x 3 i think and i have a 7 pound spring, and i see 7 pounds on the boost gauge
