ARP Header Studs
Old Sep 4, 2003 | 03:23 PM
Phate's Avatar
Default ARP Header Studs
Just wondering how many other people out there are running header studs on their LS1s. My Incon kit originally came with two studs per side, but I decided to stud all of them since a few of the bolts stripped threads when I was removing them.
The LS1 header stud sets were back-ordered through ARP, but it turns out that the DSM studs are the same specs as LS1 studs. Here is a link to where I got mine in case anyone else is interested, http://www.ffwdconnection.com/dsm2.htm
These studs are 1.75" long, but I believe there is a 2" version available as well. The quality is great, they even have a notch on the top of the stud so that you can thread them in with an allen wrench.
Thought you guys might be interested since these made installing the headers a snap. You can 'hang' the header on the studs and don't have to worry about lining up the gasket or the bolts. You can also really crank down on these without fear of stripping.
Old Sep 4, 2003 | 03:46 PM
y2khawk's Avatar
Default Re: ARP Header Studs
I've got a set i'll be using for my new headers. If nothing else, they look pretty
Alot of the "import" accesory studs will work for many of our bolts. I guess that's one of the side effects of having all metric bolts.
Old Sep 4, 2003 | 05:52 PM
Mark C's Avatar
Get out of here. I have some of those. Good to know.
They even make ones to accept larger head thread sizes. Stripped header bolt threads is a common ehough DSM problem.
The other thing about a metric car is that I usually have the right socket.
Old Sep 6, 2003 | 08:17 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Would these be of any help to a lower powered, non-turbo car?
Old Sep 6, 2003 | 11:14 AM
Phate's Avatar
For me they make putting my Incon headers up and taking them down a breeze. I am sure that they would help for NA cars as well!
Old Sep 9, 2003 | 03:26 AM
rod442's Avatar
which ones did you go with the 7 stud or the 9 stud kit? dumb question? maybe, but I like to be sure when ordering stuff I am unfamiliar with.
thanks.
