Engine Builders Help.
Old Sep 9, 2008 | 12:36 PM
knappbunch's Avatar
Default Engine Builders Help.
NEED HELP ON NEW ENGINE CHOICE. Should i build a 383 ls1 and keep my sts kit running 12 to 14 psi? should I build an ls2 408 for same or should I go normally aspirated and build the 408 and make as much as i can and keep it streetable? sts has been kind of a pain but i think most of the bugs have been worked out and i like the turbo. but this is my daily driver.
Old Sep 9, 2008 | 12:38 PM
Shawn @ VA Speed's Avatar
get rid of the sts-you are far from having all the bugs worked out
Old Sep 9, 2008 | 12:40 PM
knappbunch's Avatar
You Are All Over That One Aren't You Fine With Me If We Can Get Rid Of It And Make Same Power
Old Sep 9, 2008 | 12:46 PM
knappbunch's Avatar
how soon can we get this done? realistic time frame? and what is your suggestion on which way to go want to keep it as reliable as i can but would like 500 or more to the rear wheels. should i keep the block or get a new one?
Old Sep 9, 2008 | 12:49 PM
i'll call you
Old Sep 9, 2008 | 01:01 PM
NA$TY-TA's Avatar
U were quick on that one Shawn...... LOL
