turbine wheel flow questions
Old Sep 14, 2008 | 04:36 AM
TURBHOE's Avatar
12 Second Truck Club
Default turbine wheel flow questions
how much exhaust flow can a "p trim" turbine wheel flow? i guess its actually a 64.5mm inducer 74mm exducer incase with a .96 a/r housing. can this support 700-800whp on a ls1? or will there be ton of back pressure to worry about? with my set up i need to get the turbo spooled fast to get my heavy *** going. but with my current turbo it falls flat like 4500 5000rpm. i would like to spin easily to 6000-6500 rpm. will have a ls6 cam to help.
Old Sep 14, 2008 | 06:11 PM
TURBHOE's Avatar
does nobody know? or is there a search i should do? i tried to search but maybe i'm typing in the wrong thing.
