Any Procharger guys installed ATI Super Damper?
Moderator
OK... I went under the car to do this today and looking at the recessed area of the stock damper, I don't see how the Procharger crank pulley is going to be lined up correctly.
The ATI Performance Super Damper has no recessed area. SO, it appears the Procharger Crank Pulley would sit out way too far. Tell me I'm wrong...
Anyone know?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Anyone know?
I was thinking about getting one for awhile too. From what I know you have to get another blower drive pulley. But your in luck, it should only be a few hundred dollars from GWP!!!
Does anyone have a Fluidampr model 740102 they could measure up for me? How about an ATI 917276? I really only need a couple of dimensions so i get the axial offset and angular alignment correct for the blower belt. I'm going to design and make a pulley for the Procharger F1A kit to fit a 2004 - 2005 GTO. The more I can have made up front the cheaper it will be for all..
