Pontiac G8 ProCharger kits at EPP
Old Sep 18, 2008 | 12:26 PM
ls 2 goat's Avatar
Bob you provide me with a G8 and I will buy the kit from you and let you install it...LOL
Old Sep 18, 2008 | 01:28 PM
CHRISPY's Avatar
Thanks! There is an ATI kit out now for the 300C SRT8s as well that looks very similar. Ringlands on the 6.1 are super thin though which makes it a little trickier (even compared to gen3 GM motors)
That other kit is just fugly dude...Terrible craftmanship on the welds...
Old Sep 18, 2008 | 06:27 PM
EPP's Avatar
EPP
Thumbs up
Here are the 300C kits.
http://www.exoticperformanceplus.com...html?item=1527
http://www.exoticperformanceplus.com...html?item=1538
http://www.exoticperformanceplus.com...html?item=1539
http://www.exoticperformanceplus.com...html?item=1540
Bob
Old Sep 18, 2008 | 09:54 PM
WS6 SRT-8's Avatar
Bob, do you guys install and tune the SRT-8 kits? Thanks, Rob.
Old Sep 19, 2008 | 05:20 AM
EPP's Avatar
EPP
Yes we do, we install them on everything that ProCharger sells kits for. We even install kits on vehicles that they don't make kits for. Thanks, let me know what you are looking for. Bob
Old Sep 19, 2008 | 11:23 AM
OHSIXCTSV's Avatar
it's funny to me that the outside welds mean squat... the inside is where any
rough welds could come loose and end up in your motor.but he didnt post that pic
(inside weld seam) now did he? that's all i have to say about that.
Old Sep 19, 2008 | 01:06 PM
CHRISPY's Avatar
That's the first time I've seen the intercooler setup on 300SRT8s and I think it looks awesome! How large is the cooler, how is the flow on it?
Bob what's the installed/tuned/dynoed price with polished head unit and D1SC? (I have the diablo already, is there a discount for already owning the handheld you can upload the ATI tune from?)
Old Sep 19, 2008 | 03:40 PM
EPP's Avatar
EPP
Exclamation
There is only one weld pass there, and it is not a good one! The outside of a weld tells you a lot of what you need to know. I was all position certified for many years, and I know crap when I see it. Bob
Old Sep 19, 2008 | 07:50 PM
OHSIXCTSV's Avatar
so you're saying there is corn in that crap?
corn today...corn tomorrow...
so it is possible to turn canned corn, back into corn on the cobb?
hmmm? very interesting.
Old Sep 20, 2008 | 04:43 AM
EPP's Avatar
EPP
Thumbs up
lol, well since you added spam in my thread here about your STS kit, I'll give you my take on the STS kits. Bob
The STS kits look like a good deal, here is a list of my opinion of them, and why I don't sell them anymore:
1. STS claims that heat is not required to help spool the turbo, that exhaust velocity does the job.
Major retailers of the STS kits sell the kits with exhaust wrap, to help spool the turbo. We have done this at our shop, and it helps quite a bit. It is obvious that the closer to the engine the turbo is mounted, the more efficient it is going to be.
I copied this from the STS website.
"Doesn't heat create the velocity in the exhaust gasses to spool the turbo?
No, heat doesn't create velocity. Heat creates volume. If you look at any of the physics laws for gasses, you will find that pressure and volume and heat are related. PV=NRT is a popular one, The V isn't for velocity, it is for Volume.
The turbine housing is what creates the velocity. The scrolling design that reduces the volume of the exhaust chamber as it scrolls around causes the gasses to have to increase in velocity and pressure to maintain the same flow rate.
Hotter gasses have more volume, thus requiring a higher A/R which in effect means that it starts at say 3" and scrolls down to approximately 1". Lower temperature gasses are denser and have less volume, so they require a lower A/R housing which would start at the same 3" volume, as the turbine housings use standard flanges, and scroll down to say 3/4".
Now if you were to reverse the housings in application, the conventional turbo would spool up extremely quick, at say around 1500 rpm but would cause too much backpressure at higher rpms because the higher volume of gas couldn't squeeze through the 3/4" hole without requiring a lot of pressure to force it through. On the reverse side, the remote mounted turbo with its cooler denser gasses, wouldn't spool up till say around 4000 rpms but once spooled up would make efficient power because it doesn't require hardly any backpressure to push the lower volume of gas through the larger 1" hole."
So I take it the exhaust wrap should not make a difference?
2. You don't want to run catalytic converters with a rear mount turbo. Years ago a guy brought in a Ferrari to us that had a rear mount turbo. One of the catalytic converters internals came apart, as they sometimes do, and parts of it lodged into the turbo, ruining it. I predict that this will be happening to the STS turbo customers.
3. The oil return line is routed into the passenger side oil cap on the STS kits. This line has a habit of coming loose, and spraying oil into the engine compartment. It happened to us, and I have read where it has happened to other people.
These engines already have enough oil returning down through the heads, they don't need more! This is a bad design, and many people are rerouting the oil return line to the oil pan, where it should be in the first place. The problem with running the line to the pan is now you have to drill or punch a hole into the oil pan to run the oil line, unless you remove the oil pan. We recently removed the oil pan on a customer's car, and welded a bung into the pan for the oil return line.
4. The turbo hangs without brackets supporting it, and will sag over time. We add a bracket when we install these kits, I don't link seeing the turbo dangling there.
5. The air filter is in a bad location, as is susceptible to dust, water, dirt, etc. STS offers a cover that goes over the filter, but we found the cover seriously hinders performance. We proved that on our chassis dyno.
6. On the F Body STS kit, a driver side subframe connector cannot be used. STS claims their plumbing that is routed down the driver side does the job of a subframe connector. We find that humorous, at best!
7. The plumbing underneath the car hangs too low in my opinion, and you don't want a lowered car with an STS kit on it.
8. The silicone couplers that are provided with an STS front mount intercooler are thin, and we had two of them blow apart. The intercooler plumbing that was provided with the front mount intercooler option that we ordered for a customer's car was poorly routed, we ended up using our tubing from our front mount kits that we sell.
9. The oil lines sure have a long way to run, from the front to the rear, and back up front. If a leak developed, it could be a quick way to ruin an engine.
10. It would be relatively easy for someone to slide underneath the rear of an STS equipped car, and steal someones turbo.
11. The boost line running back up to the engine from the turbo has silicone couplers at various points along the way, and can blow apart.
12. Any exhaust leaks will diminish the efficiency of a rear mount turbo.
Old Sep 20, 2008 | 10:09 AM
CHRISPY's Avatar
Bob ignore the STS dude and PM me a price on the SRT8 kit installed with polished D1SC please
Old Sep 20, 2008 | 10:54 AM
  #32
helicoil's Avatar
Is that the same bracket used on the GTO set-up or is it closer to the engine.
Still looking for a LS engine set up for my deuce.
Old Sep 20, 2008 | 12:43 PM
  #33
OHSIXCTSV's Avatar
Bob,
I appreciate the time you took to share what you & i both know to be very true about
said kit. it does have some naging issues that should be addressed by said company.
now, with that being said, what if made the wrongs right?
ie: oil line/fitting bung to pan, wrap hot side, eliminate the shytty worm crap, adjust oil pressure to turbo side,use all t-bolt clamps, fab/make solid mounting attachment point, ...the list is getting pretty long. lol
now, if those things were (and will be) eliminated/corrected would you still feel the remote mounts are a waste of time.? ( i noticed that firechicken install you guys did and it was sick)
your answer won't sway my thinking, as i'm doing the rear mount either way, but i do respect your opinion and knowledge.
again, thanks for your time and understanding in this matter.
Ciao'
Roberto'
Old Sep 20, 2008 | 01:01 PM
  #34
Jake@EPP's Avatar
Bob,
Ciao'
Roberto'
Do you mind not 'ing this thread?
If rear mounts were so great, then why did Mike Murillo change his twin rear mount back to a front mount setup?
Sts is in the same class as the turbo-nator and also the fuel atomizer magnet
Old Sep 20, 2008 | 01:12 PM
  #35
OHSIXCTSV's Avatar
aye! put bob back on the horn...
Old Sep 20, 2008 | 01:15 PM
  #36
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
What's STS?
Old Sep 20, 2008 | 01:23 PM
  #37
OHSIXCTSV's Avatar
hey crispy, if you click the dern link it gives the price sizzlechest.
Old Sep 20, 2008 | 01:40 PM
  #38
OHSIXCTSV's Avatar
that would be a great point, if he didnt start with rear mounts btw wich
got him recognized in the first place...
look, i'm not a track *****, i'm just a guy who wants to be the 1st to install
a turbo on a cadillac...i'm no threat to anyone.
i'm just a pimp with no hoes.
Old Sep 20, 2008 | 02:07 PM
  #39
calongo_SS's Avatar
got him recognized? He was well known before he tried butt mounts.
You're a troll.
Old Sep 20, 2008 | 02:13 PM
  #40
OHSIXCTSV's Avatar
ur a h8ter. and tell your g/f to stop camping out on my front lawn.
thanks.
