TTi Race System v.Build up, Ryan K
Also more info on the Turbo, it is a Turbonetics F-1 mid frame, it has a T-4 1.01 AR exhaust and uses the Y2K compressor cover.
When we installed it and tuned it on the dyno we were making 820 to the wheels @ 19-20 psi.
Fun fun!
-Joel
-Joel
Basically, I asked for the Air-2-Air. Simple light weight and Efficient (with the right cores). The Cores are Spearco, so no cheap imports...
You could run this system on a stock engine, but as you said you would want to limit the boost untill you have real engine!
-Joel
http://home.comcast.net/~deezuns/LS1_RACE.htm
i still use the headers, up pipes, downpipe, intercooler, and all cold side piping from this kit. something approaching 4 years later!
