most boost on stock motor? handle?
Old Sep 8, 2003 | 01:13 PM
Assassin's Avatar
Default most boost on stock motor? handle?
what is the highest "safe" boost than can be run on the stock engine (bottom end) and last a while, excluding the pushrods and valve springs, cause we all know they belong in the same place as the 10 bolt... in the trash, I'm wondering if it'll be worth the headache to do the pistons and rods for FI, $ is allways an issue, want to get around 550 out of it, on 92 octane,
Old Sep 8, 2003 | 02:51 PM
smokinHawk's Avatar
Default Re: most boost on stock motor? handle?
550 on 92 octane with stock engine isnt going to happen.
Mike with the yellow CE is running 10-11psi with 105-110 octane and ran a 10.04 with stock bottom end.
that will be something to shoot for.
Old Sep 9, 2003 | 12:52 PM
tbyrne's Avatar
Those are some nice numbers! I usually say 9-10# max with the stock head gaskets and bottom end. I made 575 with the stock bottom end and didn't have a problem until that was sprayed with a 50hp shot of nitrous. The head gasket took a perminate vacation real quick.
Tom
Old Sep 9, 2003 | 01:19 PM
CHRISPY's Avatar
run 104 octane all the time and tune it fat with moderate timing. Should live at 600RWHP and 15#'s intercooled
