So whats the deal MP T76?
Old 01-01-2009, 01:59 AM
  #41
JOHNBOY66's Avatar
Originally Posted by ModularTurbo
There has been some incorrect nomenclature in the past that has caused much confusion.
The MP T76 has the following specs:
comp inducer exducer trim comp housing a/r inlet
76.5mm 103.5mm 55 .72 101.5
turbine inducer exducer trim
74mm 64.5mm 76 P-trim wheel
I am not real up on this Master Power stuff. Just a greasy old diesel guy.
If I follow this.
The Comp wheel Exducer 103.5 /Inducer 76.5.
The Turb. wheel Inducer 74 / 64.5.
That seems awful staggered to me for an engine over 300 cubes. What does a turbine of that size flow? 40lbs/min?
That would hate life on my diesel no less a higher rpm LSX. External gate would be mandatory IMHO. That is if I understand the nomenclature correctly.
Old 01-01-2009, 02:29 AM
  #42
crashly's Avatar
If I follow this.
there are new Q and S trim turbine wheels out now...
that will make a fair bit of difference...
Old 01-01-2009, 02:51 AM
  #43
JOHNBOY66's Avatar
Any idea on actual wheel sizes?
Old 01-01-2009, 04:45 AM
  #44
crashly's Avatar
i think the q trim is 74 mm inducer, 67mm exducer, and s trim is larger
Old 01-11-2009, 10:42 AM
  #45
12 Second Truck Club
TURBHOE's Avatar
I'm curios of the s trim size myself.
Old 08-22-2009, 07:13 PM
  #46
Dr. Jeckel's Avatar
Any new dyno numbers with this turbo? I have been searching for awhile, but can't find any numbers.
Old 09-27-2009, 09:00 AM
  #47
Dr. Jeckel's Avatar
New updates with real world experience on this turbo???
Old 09-27-2009, 08:43 PM
  #48
Vcious04's Avatar
Ok so that the New T76 versions are out and available now.
$775 MP T76 S trim
$775 MP T76 Q trim
Thats the one I have and should have some solid dyno #'s on my custom front mount this week.
Oh and BTW, it makes 10psi between 2800-3200rpm.
Quick Reply: So whats the deal MP T76?
