how much boost
Old Sep 26, 2008 | 06:47 PM
mjm02ws6's Avatar
Default how much boost
I'm looking to put either a supercharger or turbo on my 02 ws6. how much boost is safe to run without harming the motor? The motor has heads and cam, its a trick flow top end kit. A few other things here and there, but nothing on the lower half of the motor. I have 422rwh and 416tq. Looking for info and tips on how to get more!
Old Sep 26, 2008 | 06:54 PM
MadIceV8's Avatar
Customizing Director
From what I've read it seems 8lbs is the limit. I plan to run 8 or less if I install my kit.
Old Sep 26, 2008 | 06:57 PM
98Z28MASS's Avatar
depending on your current CR with your heads and cam setup usually the limits on the stock shortblock are 7-8 psi. Id say if your heads are milled and you have higher compression then 5-6 psi max would be what I would go with. At 422 rwhp NA you would be looking at over 500 rwhp at 5-6 psi and over 550 rwhp with 7-8 psi. I would say your best bet would be to go with a D1SC kit from EPP. Complete kit with fuel system upgrades and their service, cant beat it!
Old Sep 26, 2008 | 07:36 PM
engineermike's Avatar
Originally Posted by mjm02ws6
... how much boost is safe to run without harming the motor? ...
If I had a dollar for every time I read that, I could bail out a few financial institutions.
Old Sep 27, 2008 | 12:56 AM
Gordon0652's Avatar
Some guys will push 9# IMO i would stay under 8# with a very good tune.
lol^
