Track results TC 78
Old Sep 28, 2008 | 09:00 PM
Zombie's Avatar
Originally Posted by code4
I am not a rear mount, sorry if I made it sound that way. Here is my set up.
https://ls1tech.com/forums/showpost....4&postcount=15
oops, thought you were a rear mount. Still duplicated the 2.75 gear results
Old Sep 28, 2008 | 09:57 PM
2 SSlow's Avatar
Very cool. That's damn near identical to the set-up I'm working on. If I can get anywhere near that MPH out of my 6-speed, 3.50 gear set-up I'll be VERY satisfied. 135mph should make a damn good street car.
What CI engine do have in your car?
Old Sep 28, 2008 | 10:37 PM
code4's Avatar
Originally Posted by 2 SSlow
Very cool. That's damn near identical to the set-up I'm setting up. If I can get anywhere near that MPH out of my 6-speed, 3.50 gear set-up I'll be VERY satisfied. 135mph should make a damn good street car.
347 ci
Old Sep 29, 2008 | 02:07 AM
venom ws7's Avatar
So your not happy about the ET???
CONGRATS You have a 9sec street car in your hands once you fix all the bugs.
Old Sep 29, 2008 | 02:49 AM
bluecamaroz28's Avatar
Not bad, not bad at all 136MPH and good R/T.
Old Sep 29, 2008 | 09:32 AM
sciff5's Avatar
These are good results but when I think about it at 14-15psi shouldent you be making a good 700+whp at least?
I would think 700whp would be good for a little better trap speeds.
Of the few cars running the TC setups (that have posted numbers/results) the ETs are all in the 10s and traps in the high 130 range. Not that this isnt great and all but I would think you should be able to get better results out of a turbo thats capable of whats probably 900whp. With that amount of power shouldent cars be knocking on the door of 8s at 145mph?
This is an honest question..which I'm asking only because I'm interested in getting a TC series turbo for my own setup.
Old Sep 29, 2008 | 09:39 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
sciff I went 9.40@143 1.35 with my old blower setup at 680rwhp a few years ago, around 3400 raceweight.
I think 10.1/10.2@136-139 is strong and is probably around 650-700rwhp.
Getting it to run a little quicker and faster might just require a little more seat time, but in all reality it might force him to make changes he doesn't want to make.
Car have a roll bar in it?
I went 10.05@137.7 1.51 last weekend on 16 psi, if I worked on getting the past pass at this boost level it would easily go 9.8@140 on a 1.4x and with more seat time. I'll probably try it anyway.
Old Sep 29, 2008 | 09:44 AM
SPRAYED 01's Avatar
Im hoping for a 10.5 with my tc78 in my 3800lb T/A. My mph has always been really low with my setup. I was only doing 122mph running a 10.8 with my pte67. I could not even imagine running even 130mph.
Old Sep 29, 2008 | 09:47 AM
LS1Tech Co-Founder
Alex, I think you need to play with how you stage the car and stuff. Remember when we were messing around on the highway? My GT47-88 is laggy at lower rpms, but once it was in the power band it was move. That was 16 psi, and that's the same combo that I went 10.05@137.7 at GLD.
Old Sep 29, 2008 | 09:55 AM
SPRAYED 01's Avatar
John,
I just reinstalled my new trans and i went with a vig 3600 instead of my old 3000 stall. So im hoping that will help my launch. Its going on the dyno this saturday to retune for the new stall. I would hope it could do 600whp lock on a mustang dyno which should be good for 130mph. I just dont see it happening for some reason.
Alex
Old Sep 29, 2008 | 10:07 AM
LS1Tech Co-Founder
Have to see. A Vig 3600 can be pretty loose, let's see what it does at the track. Worst case it leaves hard but drives through the converter on the big end.
Old Sep 29, 2008 | 10:10 AM
  #32
SPRAYED 01's Avatar
I also upgraded to a 3disc so if its blowing through i can try locking it up in 3rd.
Sorry to highjack.
Old Sep 29, 2008 | 10:11 AM
  #33
DrTurbo's Avatar
LS1TECH Sponsor
A full weight street car and he ran 139mph.....that's 700rwhp maybe a touch more. Seat time is the major difference........ask Josh @ KYTP. His old car with some seat time and a TC76 went pretty dang fast. The first few passes were only mid-10 passes. The car dipped into the 9's@ over 140 I believe.
Old Sep 29, 2008 | 10:14 AM
  #34
hellbents10's Avatar
LS1Tech Sponsor
Nice numbers on the little TC.
Old Sep 29, 2008 | 10:30 AM
  #35
code4's Avatar
It did 6.1 in the 1/8 but third gear was cutting out. Like it was too rich but the WB was reading ok. I am wondering if my WB is going out IDK.
The problem is I don't live anywhere near a track so any tuning is done on the street. I will not tune at 130 plus on the street. I will try to go back next year & figure things out & see if it will dip into the 9's.
Old Sep 29, 2008 | 10:50 AM
  #36
fenix999's Avatar
Maybe the load that you're getting at the track is sooo much that it is changing the way your car is driving. The load that you get on the street as opposed to a nicely prepped track can affect the way the car runs, but you obviously already know that Awesome numbers by the way man, keep it up! You have high 9's and 140mph in you, i know it!!!
Old Sep 29, 2008 | 03:37 PM
  #37
bad2000z's Avatar
Bad ***! I want a turbo setup soo bad.
Old Sep 29, 2008 | 04:42 PM
  #38
sciff5's Avatar
Btw when are you hitting full spool?
I know it will be different for me beause I'm going with a T56 but I'm just curious cause I'de be running truck manifolds too
Old Sep 29, 2008 | 07:04 PM
  #39
frcefed98's Avatar
Man those times are great looks like i'll be upgrading my lil TC76 to 78 status after seeing this run. A/F good, and still nosing over.....could be pulling some timing. Did you log your pass with HPT or EFIlive?
J
Old Sep 29, 2008 | 07:29 PM
  #40
code4's Avatar
Yes I did, no KR everything looked pretty good. It felt identical to a way rich condition. My car will start to sputter at around 10.7 to 1.
I ran some leaded fuel for this weekend & I am wondering if my WB is off.
