Track results TC 78
Old Oct 2, 2008 | 07:22 PM
  #41
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Hey Code, if you don't mind I have some q's for you....
-T400 yes?
-Where you racing at?
-What gas are you running?
-Is that turbo from Jose @ FI? How big is it, 78mm T4? How big is it overall sizewise?
-HPT 2 bar, SD?
-What rpm you shift at?
-How long do you have to brake it to get into boost at the track?
I'm thinking I'd maybe get one of these turbos for my Speed Inc. truck manifold kit, and put this kit in another car I'm looking at
Old Oct 2, 2008 | 08:31 PM
  #42
code4's Avatar
-T400 yes? It's a T400 with some special goodies
-Where you racing at? Spokane WA the track elevation is 2500 FT
-What gas are you running? I had some 110 race gas that I have since found out may be oily? IDK the brand but I will not use it again
-Is that turbo from Jose @ FI? How big is it, 78mm T4? How big is it overall sizewise? Yes I got it from FI.com It is the tc 78, it is tiny I still use puller fans with a turbo blanket
-HPT 2 bar, SD? Yes
-What rpm you shift at? My light comes on at 5800
-How long do you have to brake it to get into boost at the track? It is super quick, watch this vid & you can hear it. Some guy was filming at the track & posted on his site. Quality vid compared to mine vid.
http://vimeo.com/1859232
Old Oct 2, 2008 | 10:20 PM
  #43
SPRAYED 01's Avatar
God i hope my tc78 setup works as well as yours. Not sure if this has been asked but are u using a t-brake?
Old Oct 2, 2008 | 10:37 PM
  #44
DrTurbo's Avatar
LS1TECH Sponsor
-HPT 2 bar, SD? Yes
Awesome run and all, but what video recorder did you guys use. That is a DANG crisp image! What brand and model?
Old Oct 2, 2008 | 11:50 PM
  #45
code4's Avatar
Canon vixia HV30 w/a shotgun mic
Old Oct 3, 2008 | 08:59 AM
  #46
code4's Avatar
Yes it has a t brake. Funny thing is that I have a 2 step also but it went bad the day before. It just made the engine die without engaging it. I am sending it back to LPE.
Old Mar 30, 2009 | 06:52 PM
  #47
TURBHOE's Avatar
12 Second Truck Club
what wastegate are you using? i seem to getting bad boost creep with my tc78 and turbonetics 38mm.
Old Mar 30, 2009 | 10:35 PM
  #48
LASTLS1's Avatar
6 Second Club Moderator
Originally Posted by Zombie
It's very nice to see that someone has duplicated my setup and results. Congrats on the time. There are now 4 rear mount f-bodies I know of in the 10.10-10.20 range. I'm only the leader temporarily for now
I love seeing someone else prove that the 2.75's can work well for a street car. They definately aren't optimum for drag racing but they still work decent.
I run 3.23 gears.
Old Mar 30, 2009 | 10:36 PM
  #49
LASTLS1's Avatar
The TC turbos work well!
