which supercharger?
Procharger
texas speed 1 7/8th LT headers with tsp catted Y pipe
borla catback or b&b tri flo catback
What else do I need to really get this thing to perform? i don't want to spend too much on this car but I do want it to be fun. I have a 2006 corvette which will now get a heads and cam package instead
Anyways I'm a total newb when it comes to engines etc. I have heard from someone else the procharger is a good kit thats easy to install (I'm not installing it myself but I guess less labor) If some other supercharger package woudl be better please suggest it. If any other mods are needed please suggest those as well. Also will this car still have the ability to be daily driven after those mods?
Thanks in advance!!
Ricky
You will need to upgrade the fuel system as well.
Also, I think the P1SC kit has CARB #, which would mean you can put it on the C6. You'll just need a good tune and cats and a friendly inspector to pass you on the visual if you put headers on it. Should pass emissions testing no problem
Procharger
Thanks in advance!!
Ricky
FI will cost you 25-50% more than you think it will, or $5K-10K depending on the setup, supporting mods, mods to handle the added power, etc.
Headers, cat back and a P1 will be a whole other ball game from where you are now.
The advantage of the D1 is if you push the stock motor too far and blow it up you may as well go to a built motor. At that point you'll be wishing you had the D1 so you can push things farther.
Read the stickies at the top, FI is probably a lot more expensive than most initially think it is.
http://www.exoticperformanceplus.com....html?item=540 Bob
