Ebay kit questions
Old Oct 2, 2008 | 01:36 PM
98Camarod's Avatar
Default Ebay kit questions
I've got parts coming in and I'm out of town. Hopefully I'll have enough parts to get this going pretty good. However, I'd like to know what:
-v band clamps you all are using, how much, where from and what sizes
-oil feed and return setup, how much and where from
So far I have on the way are:
-the kit
-gt4294 turbo
-bov
-cold pipes
-exhaust wrap
-255 walboro pump
I know I need a waste gate, blanket, and solid mounts. What else do you think I'll need?
Old Oct 2, 2008 | 01:46 PM
98Camarod's Avatar
Also what size wastegate should i run with my setup do you think?
Old Oct 2, 2008 | 03:31 PM
Hennytime's Avatar
im going to run a tial 38mm on a t70
Old Oct 2, 2008 | 03:36 PM
brokeLS1owner's Avatar
prolly a tial 44 for a 42r
Old Oct 2, 2008 | 03:52 PM
98Camarod's Avatar
What about the clamps and oil feed/return kit with a link pmed?
Do you think 3an is a big enough supply? I have found a universal kit but I'm not sure if thats enough.
Old Oct 5, 2008 | 07:14 AM
defaultexistence's Avatar
napa auto parts will be the one stop source for all of your v-bands and t-bolt bands ,i still am replacing crappy t-bolts from my cold side kit...get the ones that have the guide walls..silicone is found all over the net, check out ebay..make damn sure you get 3 or 4 ply only... i ended up with bullshit couplers that came with my cold piping kit....good only for mocking up kit
Old Oct 5, 2008 | 03:37 PM
98Camarod's Avatar
What about the pipe that bolts to the wastegate, was yours not welded? it looks like it will allow adjustment and then it must be welded. Is that correct?
