Forced Inductions Turbo Stress Test
Amazing the turbo lasted with that heat.
If you have a large enough fir extinguisher that you can be sure it will do the job, then maybe it is worth the risk.
Id say more often than not, they stop with a rod out the side of the block.
Yup, this one stopped when the pistons decided to exit out the exhaust valves.
come to find out it was something that i took a shortcut on,needless to say i have never bought a important part used or tried to fab one up since....Im glad its a great built unit cause i have one of their turbo's and i do stupid stuff when im drunk.....sorry to hear about his lose..
On a 12 valve Dodge, there's a mechanical lift pump that feeds the high pressure pump. On a 24v, there's an electric lift pump that feeds the injector pump. These fail often and take out the injector pumps on the 24v trucks.
For those curious,
Nick
People think LSXs are expensive. You can have a nice short block for what Dmax rods cost. LOL
In a spark ignition engine, the flame front propagates outward from the spark plug and happens relatively fast. Fast enough that it's usually modeled as a constant volume with sudden pressure increase event. A diesel on the other hand, ignites when the compression causes the air in the cylinder to become hot enough that it ignites the fuel. Well, if the diesel fuel is atomized better thru injection at higher pressures, this SHOULD occur simultaneously throughout the cylinder. Typically diesels are modeled as a constant pressure w/volume change event. If the diesel could be ignited more uniformly and rapidly, then the pressure in the cylinder at TDC (or close to it) would be much greater and able to do more work on the piston as it goes down in the cylinder.
