PTK Downpipe
Old Oct 8, 2008 | 10:08 PM
red90cobra's Avatar
Originally Posted by 98Camarod
Your running a 70 and mines a 76. The size is the same, just my outlet is 3.5"s and yours is 3". It's some BS
yeah you should sell the one you got and get one that fits. it's too much of a hassel to try and make a 3.5 dp work where the turbo sits.
Old Oct 8, 2008 | 10:34 PM
Monello's Avatar
i agree
We arent tryin to **** you off, just trying to help you so you dont get pist when you run into all sorts of issues with trying to make it fit.
Old Oct 9, 2008 | 06:49 AM
98Camarod's Avatar
Don't worry I'm already pissed. It didn't say that it would require a 3.5" downpipe. I figured since they were the same size as the 70 that they would require the same size downpipe. I'm still not sure what I'm going to do yet.
Old Oct 9, 2008 | 09:29 AM
nossty1's Avatar
Well, I got an PTE88 in there so yes it can be done. You will start running into spool issues down the road. Mine is necked down and still makes the turn but spool time is horrible.
I just looked at it and we just welded the orig downpipe inside the new flange that i got with the new turbo.
I am in the process of building a kit from the ground up now. I wish I would have never tried to modify the kit. I am sure this is not helping your post much but I am trying to warn you. Though I am sure the 76 is easier to fit than my 88.
Good luck man.
Old Oct 9, 2008 | 10:00 AM
98Camarod's Avatar
Do you have any pictures? What size downpipe did you need the 3.5"? Since your building a new one, it sounds like you wont be needing that one then and I just so happen to need it possible trade action
Old Oct 9, 2008 | 10:28 AM
nossty1's Avatar
Its the stock DP with the bigger flange for the 88 on it. I am sure we could work something out.
Attached Thumbnails PTK Downpipe-101_0965.jpg   PTK Downpipe-101_0968.jpg   PTK Downpipe-101_0969.jpg
Old Oct 9, 2008 | 11:18 AM
98Camarod's Avatar
How the hell did you do that? It's a 4.5" clamp right?
Old Oct 9, 2008 | 11:19 AM
98Camarod's Avatar
Have you taken it off of the kit yet? I'd like to see it by itself if possible.
Old Oct 9, 2008 | 11:24 AM
nossty1's Avatar
I actually just walked outside to the car for those pics. If I get some time I might be able to take it off so you can see it off the car. I have been meaning to get rid of everything after the DP anyway. It necks down in such a short distance that it is restrictive for my 88. Might be ok with your 76 though.
Old Oct 9, 2008 | 11:29 AM
98Camarod's Avatar
It's still SS though right? You are going to be selling the entire kit right? I'd be able to trade you so you wouldn't be without a dp when you sell it. Let me know what you want to do.
Old Oct 9, 2008 | 11:37 AM
nossty1's Avatar
This pic might be a little better. I walked out and pulled the blanket back.
Old Oct 9, 2008 | 11:42 AM
  #32
nossty1's Avatar
No this is a real PTK kit not ebay. It is coated. Also I wouldnt really need yours. There is not much call for a modded PTK kit for an 88mm turbo. Its to restrictive. Most of the piping will probably be trashed or reused on a buddys car. If you arent intrested in mine call up Jose at Forced inductions. I am sure he can get you what you need. He is a great guy and def knows his stuff.
Old Oct 9, 2008 | 11:50 AM
  #33
98Camarod's Avatar
I hear they are always backed up and have a problem delivering on a schedule. I'll be wrapping the downpipe anyways. Are you going to be taking it off soon? I'm trying to get this done quick.
Old Oct 9, 2008 | 11:56 AM
  #34
nossty1's Avatar
I got mine when they first came out. I still ended up waiting 4 months or so.
I hadnt really intended to hurry the process. How fast were you thinking?
Old Oct 9, 2008 | 12:26 PM
  #35
98Camarod's Avatar
yesterday
How long is your drain line? I was only supplied with a 16" drain line. And where did you tap it at?
Old Oct 9, 2008 | 12:34 PM
  #36
nossty1's Avatar
I seem to remember mine being 24" and we tapped it at the front drivers side.
Old Oct 9, 2008 | 01:13 PM
  #37
bboyferal's Avatar
I think the biggest anyone here has gone without modifying the kit (3 inch dp) is Frost with a 76GTS.
Old Oct 9, 2008 | 01:18 PM
  #38
nossty1's Avatar
I think your right.
Old Oct 9, 2008 | 01:45 PM
  #39
98Camarod's Avatar
Any chance you would be taking it off soon or could you point me in the direction you got the clamp from?
Old Oct 9, 2008 | 01:52 PM
  #40
nossty1's Avatar
haha, Check out post #32. It would probably be better if you went that route anyway. SS is pretty!!
