370 billet 85mm 8.87@150 on Pumpgas Upgrading to 25.3 going for 7s
Lots of guys running that combo really hard, @Prostock John is building one right now.
Upgraded 9 Blade Turbine Wheel 96*88mm for 400 Series Turbos -
I get you're a 102mm but perhaps they make one for that size too.
I'd probably leave it alone for a bit and go get that 7.
FIS has some bigger turbines offered in their GTR line?
Forced Inductions. GTR 102
Someone would definitely scoop up that current turbo.
What BTR cam is it? Could be too small for a 427 for sure, or that turbo is just plain DONE on that engine. That's a 200 rwhp drop from where the converter coupled to where you let out at 175 mph so I would want to correlate that with engine RPM to see where it was really happening.
If he had enough cam or turbo it should continue to carry out correct?
Forgive me if the questions are dumb, trying to learn this stuff lol.
Cam was made for this setup and even the btr said turbo had to small of exhaust side. More boost means more back pressure with rpm = less power. Can not fit any turbo that is bigger outside dimensions
