Questions on fuel pump sock install
Old Oct 19, 2008 | 10:28 AM
Gottahavels1's Avatar
Default Questions on fuel pump sock install
So I installed a new walbro 255 pump and i was concerned about how the sock was stuck inside the pump assembly when you push the pump back in. Is there any other way to hook up the filter so it doesn't get bent? I noticed that the stock filter sock was small enough to not get jammed up the side of the pump assembly, but the walbro came with a much larger filter sock. do you guys have any ideas?
