Autometer Fuel Pressure Gauge HELP
Old Oct 21, 2008 | 03:00 PM
witry's Avatar
Default Autometer Fuel Pressure Gauge HELP
i just got my gauge in today and want to hook it up its the electric type and i need to know what fitting to buy to attach it to my fuel rail some quick help would really be appriciated thanks
Old Oct 21, 2008 | 03:21 PM
jimmyblue's Avatar
Moderator
The sender is probably 1/8" NPT, for my use I took
a cheapo Actron gauge with its Schrader fitting and
put a T-block & nipple to hook the dial gauge and
sender to the hose.
If you have aftermarket rails then probably just
pipe bushings; for stock you need a Schrader
fitting and it's going to be kind of a contraption
I think. You might also be able to work with the
soft line, get some fittings and T into that but
you're dealing with high fuel pressures and it
might not go so well (reliable) as hard plumbing.
Old Oct 10, 2010 | 02:30 PM
poltergeist 02's Avatar
Metco Motorsports PN MFP0001
Old Oct 10, 2010 | 03:32 PM
1lejohn's Avatar
The easiest way is to buy a length of AN line that runs from the fuel rail to an adaptor (AN to pipe) You need to remove the scharder valve out of the rail.
Old Oct 10, 2010 | 08:05 PM
Texhotrod593's Avatar
Ok guys, correct me if im wrong.... The sender is a 1/8"npt and the stock fuel rail schrader is a 1/4 flare. If you hold your money and go to any a/c refrigeration dealer I.E. Barsco, united refrigeration, weathertrol, coburns etc they will have those fittings. I didnt want to purchase a sending unit and mess(I have their Phantom2 line fuel gauge), so I used a Novar pressure transducer 0-100psi/0-5vdc and was able to find all my fittings at the supply house. I put a tee w/ schrader so i could tap onto it later if I wanted to. Good luck
