done everything else i can think of...fuel pump?
I've changed the filter, and stock fuel pressure regulator (intank, I found a site that sells them separate from the whole assembly). I checked the voltage at the pump. I stripped wire off the pos./neg. and used alligator clips to get the voltage with my multimeter. Voltage from idle to WOT is 13.6 to 13.8 Volts.
I thought the problem might be electrical. The battery is almost a year old so I think that it's okay. There don't appear to be any charging problems. The car starts perfectly and lights, and stereo (2 amps, sub, aftermarket speakers) run fine.
All this leads me to think the pump is going out. It has 25k-30k miles on it. The good voltage at WOT and the fact that the idle pressure has gradually decreased over the last 3 years leads me to think it's the pump. Does this sound right?
thanks!
Even though the idle pressure was 62, it should be 58. This was due to the larger pump overloading the stock regulator at idle.
If your pressure is now lower, either the pump is getting weak, or there is an internal leak at the fuel hose or somewhere else in the tank.
Does your pressure hold once you shut the car off?
Does the pump prime & does the car start easily?
