42lb Injectors too much?
Old Oct 28, 2008 | 07:18 PM
MrDavid's Avatar
Default 42lb Injectors too much?
Just finished building my 383LS1 with Stage II 5.3 heads and MS4 camshaft. I found green top 42lb injectors a few months ago for a good price so I bought them. Now, i'm thinking that they might be a little much for an all motor car that will be <500hp with the LS6 intake and stock ported TB. Could they pose an issue below 3K rpm by not being able to spray a small enough amount of fuel.
I also have a Walbro 255lph pump and have just over 65lbs of fuel pressure at idle.
Old Oct 28, 2008 | 09:30 PM
Gordon0652's Avatar
42# sounds great for your app.
Old Oct 28, 2008 | 09:32 PM
heavy6.0's Avatar
42lbs is perfect!
Old Oct 28, 2008 | 10:04 PM
ZL1Killa's Avatar
you are fine. those will run fine and you will have no problems
Old Oct 29, 2008 | 04:46 AM
MrDavid's Avatar
OK, thanks. Car is being base-tuned now so I can rack up some miles on it before WOT tuning.
Old Oct 29, 2008 | 03:22 PM
Viper's Avatar
Yeah your fine. I have them on a 346 with H/C and 90 intake and it runs great, idles good and sub 3000 is fine.
Old Oct 31, 2008 | 07:16 PM
2001z's Avatar
Dave break that thing in for we can see what that beast can do at wot!
Old Nov 1, 2008 | 01:46 PM
LT SLO's Avatar
I would stick with those for sure!!!
Old Nov 1, 2008 | 05:28 PM
MrDavid's Avatar
Working on it Tim. Slowly working on it. The block is too thirsty for oil right now.
