Injector question
Old Nov 2, 2008 | 11:04 AM
chewy99ws6's Avatar
Default Injector question
I have done some searching on here but haven't found the answer I am looking for. I have a T-76 turbo, 10psi for now till I get used to it, 60# injectors, 255 in-tank pump, and when we were tuning it was maxxing out the injectors at 6600rpms. Question is do I need to go dual in-tank 255's? I am planning on doing it soon, just want to know what ya'll think before I do anything. Oh yeah fuel pressure is 58psi. Thanks in advance
Old Nov 2, 2008 | 11:46 AM
405HP_Z06's Avatar
When you say 'maxxing out the injectors' I assume your talking about injector duty cycle. This is a different condition than what you describe above.
The fuel pumps must supply the needed volume and pressure to support your horsepower level. Is your fuel pressure a steady 58 to red line?
Old Nov 2, 2008 | 11:50 AM
chewy99ws6's Avatar
Yes sorry I meant at 6600rpms, my duty cycle is 100% and yes it is 58psi steady.
Edit.. at 50% throttle I am at 60% duty cycle
Old Nov 2, 2008 | 12:12 PM
405HP_Z06's Avatar
What about you’re A/F ratio's? Are you going lean on the top end? No doubt you probably need bigger injectors, but the fuel pump/delivery system is a different story.
