Where to find injector offset values...
Old Sep 19, 2003 | 02:05 PM
Ryan23silverado's Avatar
Default Where to find injector offset values...
For tunning, where do you find injector offset values when you put in non-stock injectors. Does anyone know where I could find the values for THIS injector, a Delphi/Lucas 42lb '.009' injector? Thanks for your help
Old Sep 22, 2003 | 07:05 PM
flyinZ's Avatar
Default Re: Where to find injector offset values...
Im in the same boat as you....Im lookin' for the offsets for Accel Injectors...
Old Sep 23, 2003 | 07:18 AM
EVIL's Avatar
i got an excel spreadsheet from someone on here to do this.
i cant remember who, and its on my old computer which i cant get to boot up.
you put in the flow rate at 43 psi of fp and it recalculates it for 58 psi and gives you the edit values.
Old Sep 23, 2003 | 12:33 PM
red ws6 99's Avatar
EVIL, they want injector offset tables (injector opening response) not injector flowrate tables. Racetronix should be able to get you one. Although in past posts they have just stated they tweak the injector flow rate tables to compensate. I searched through the lt1 and ls1 edit archives and found enough information to piece a table together (along with Chris B spreadsheet)
Gary
