Racetronix pump not getting power?
Old 12-08-2008, 07:53 PM
Restricted User
socmguy's Avatar
Default Racetronix pump not getting power?
I just installed my Racetronix in tank pump with jumper wire and the car won't start. The hot wire is connected to the Alternator and the relay is grounded as well. The fuse is intact so I know that's not it either. When I turn the key to run I don't hear anything. I've had a friend turn the car to start with the schrader valve on the fuel rail pushed in and nothing. I got my multimeter out and checked voltage to both wires connected to the relay. I'm getting power to the power wire but 0 volts on the output no matter what position the key is in. Everything was connected as per the directions and I even filled the bucket up before everything was put back in. What would cause the jumper wire not to put voltage to the pump? Here is a pic of the relay and ground so you can tell they were done correctly.
The two red wires were the ones tested for voltage. You can see the ground is in a good spot as well. Anyone have any ideas?
Old 12-09-2008, 08:51 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Check the grey wire at the relay & see if it gets 12v when the key is first turned on. This is what activates the relay. I'm assuming the relay does not click at key on.
If you get no power here, then check the factory pump relay or fuses or the connection where the factory harness plugs in to the hot wire kit.
Old 12-13-2008, 12:24 AM
LS1TECH Sponsor
Racetronix's Avatar
Please contact our support dept. and we will get back to you ASAP.
http://www.racetronix.com/support.html
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 12-13-2008, 10:10 AM
Restricted User
socmguy's Avatar
Checked power at the gray wire and got nothing. Do I have a bad relay?
Old 12-13-2008, 10:22 AM
Restricted User
socmguy's Avatar
Message sent
Old 12-13-2008, 05:13 PM
LS1TECH Sponsor
You never called back after our phone conversation......
Power to the grey wire comes from your car. If it does not have power, there is likely a bad connection where your factory harness plugs in to the Racetronix harness or the factory relay/wiring is not sending the signal for some reason.
If the grey wire has power, then the relay could be at fault, but in this case nothing is commanding the relay to energize.
Check your connections.
Old 12-13-2008, 06:23 PM
Restricted User
socmguy's Avatar
OK, I'll drop the tank down and check again.
Old 12-14-2008, 12:39 PM
LS1TECH Sponsor
Racetronix's Avatar
Check the docs we sent you.
The gray wire can be traced back to the factory bulkhead connector beside the relay. You can test there for factory pump power before you drop the tank.
__________________
>WEB SITE<
Old 12-15-2008, 04:06 PM
shadowsnkx's Avatar
hey racetronix. How about my problem. It was NEVER resolved.
Old 12-15-2008, 05:51 PM
Viper's Avatar
Perhaps you should contact them through a PM instead of posting in socmguy's post.
Old 12-20-2008, 04:35 PM
Restricted User
socmguy's Avatar
OK, I just checked all the connections and it was a little loose. Got everything back together and now I'm burning fuses. Am I supposed to put a bigger fuse in? I have a 20 Amp mini fuse in there right now.
Old 12-20-2008, 05:12 PM
koolaid_kid's Avatar
If it is popping fuses that is an indication that you have a short to ground. Do you have an Ohmmeter? Sounds like time to start buzzing wires.
Old 12-20-2008, 11:42 PM
Restricted User
socmguy's Avatar
I don't think anything's grounded out anywhere. The jumper wire kit is installed in accordance with the directions. Where else could it be shorting and how could I tell? I just put in a 25A fuse in there and it blew that too. What should I check next.
Old 12-21-2008, 01:13 AM
LS1TECH Sponsor
Racetronix's Avatar
You will get much faster resolution to your problem by keeping an open dialogue with our support dept.
__________________
>WEB SITE<
Old 12-22-2008, 03:21 PM
Restricted User
socmguy's Avatar
I traced the pnp wires and nothing's grounded out. The fuse pops as soon as I turn the key from off to run. Could it be the relay?
Old 12-22-2008, 06:00 PM
Restricted User
socmguy's Avatar
Fixed it.
Old 12-22-2008, 06:02 PM
Viper's Avatar
What was it?
Old 12-23-2008, 06:15 PM
Restricted User
socmguy's Avatar
Easy, I just removed Racetronix's plug and play kit and reinstalled the factory wiring. Works like a champ now!
Thanks to Racetronix's tech support, you should have suggested that to begin with. (Too bad you can't type in sarcasm!)
Old 12-23-2008, 07:11 PM
LS1TECH Sponsor
Racetronix's Avatar
When you jump from one test to the next or use the 'swap method' to diagnose your problem you will not be able to isolate the problem!
- If The Racetronix harness blows the fuse before you even cycle the key then you have a shorted power wire (to ground) between the fuse and the relay.
- If the Racetronix harness blows the fuse after you cycle the key without it being plugged into the fuel module you have a short (to ground) between the relay power output the sender.
* This is assuming you are using quality 20 amp fuses and there is no pump booster installed on the harness.
If the harness has been compromised we will repair or replace it free of charge.
We are opening a RGA for this harness so you can send it back here no charge via UPS. An e-mail has been sent to you asking for some contact and shipping info. A copy of your sales receipt will also help speed things along.
There has to be a simple explanation as to why a harness would test OK after production and then have a short to ground popping fuses once installed.
Either way you will end up with a working harness.
__________________
>WEB SITE<
Old 09-17-2016, 04:49 PM
5.7stroker's Avatar
Bumping this 8 year old post, but isn't the point of having the racetronix hotwire kit because the factory wiring can't support the racetronix pump?
Quick Reply: Racetronix pump not getting power?
