How much RWHP can the SVO 30 lb/hr support with Racetronix?
LS1TECH Sponsor
Re: How much RWHP can the SVO 30 lb/hr support with Racetronix?
New lb/hr = sqr(new pressure / old pressure) x Old lb/hr
30's would be 34.6lb/hr @ 400KPa / 58PSI.
Assuming a max recommeneded DC of 80% in order to maintain stable injector timing = 27.7lb/hr.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
I am getting the SVO 30 lb injectors and tuning...I am about 430 rwho and am installing a 200 hpo wet system...will a racetronix intank unit and boost a pump work for this or would I need two 340 pumps???
Any word on a new vendor for the dual intank racetronix unit???
LS1TECH Sponsor
With a booster you would have more than enough.
A DP system is not required.
__________________
>WEB SITE<
>WEB SITE<
thanks for the input...I would assume I would want the boost a pump (MSD) to activate when the nitrous is armed (wouldn't need it all teh time). Is there any word on the 99+ Racetronix kits availability? Would it be possible to simply use a metal 98 gas tank in a 2000 F-body so I could get the racetronix kit?
Thanks
Thanks
