I need yalls help...
Old Dec 31, 2008 | 10:36 AM
gnictry's Avatar
Exclamation I need yalls help...
I know I not mean to do another mpg thread but I am at a lost.
About two months ago I installed my 228 cam and was getting 16-17mpg around town and some highway.
Although two or so weeks ago I dropped to 14.5mpg regardless of how or where I drove...I mean back roads and cruise control on highway did not change it.
I have replaced the air filter, fuel filter done at 95k currently 117k, plug and wires checked at cam install, maf cleaned, and injector cleaner put throw gas... did not help
So I replaced the front two o2, backs are tuned out and drove....
A friend w a snap on scanner scanned the car tring to help figure it out and it showed my front pass not reading right so I returned it and put one of the removed ones back.
Now we have not had a chance to scan car again but replaceing the one did not effect it...I still get 14.7mpg
What could it be?
Old Jan 1, 2009 | 08:51 PM
gnictry's Avatar
Question
anyone?
Old Jan 2, 2009 | 11:02 PM
gnictry's Avatar
Question
any way to test injectors?
still not able to scan to check pass. o2 but I not have ses light and car running smooth...
any suggestions are welcome!
Old Jan 2, 2009 | 11:38 PM
Frost's Avatar
Hey,
As a rule, if one has more than 5K miles on it, I always replace them as a set. If they are in good shape and you are driving for mileage, it really should be there. I know that's not a lot of help.
Old Jan 3, 2009 | 09:42 AM
gnictry's Avatar
I replaced the driver one and pass but the new pass one wasnt reading write so I put one of the older ones in place of it...it looked good barely any build up ...just need to rescan it but it feels strong so not sure
Old Jan 3, 2009 | 10:27 AM
Frost's Avatar
can't judge the condition by how they look though, and they will not have any effect on WOT, just cruise and normal driving. These sensors switch back and forth with fuel trimming to keep the car at a 14.6:1 AFR all of the time except first startup and WOT. They are literally the feedback needed for proper fueling. I'm not saying that this *IS* the problem, but it's the highest likelihood.
Old Jan 3, 2009 | 10:36 AM
edcmat-l1's Avatar
Did you check your tire pressure? I know it sounds stupid, but it's the simple things that get ya.
Also, jack it up and make sure none of the brakes are draggin.
Old Jan 4, 2009 | 10:12 AM
gnictry's Avatar
good ideas...
tires are all at 33 w nitro...brakes are not draggin
trying to get another o2
 Michael S. Palmer
Old Jan 4, 2009 | 03:47 PM
gnictry's Avatar
yesterday did a highway road trip and averaged 17mpg...still low but not as bad
Old Jan 20, 2009 | 11:41 AM
gnictry's Avatar
will I cant scan the pass o2 sensor so I guess Ill have to replace it because I calc. that highway I got 13.95 yesterday thats 188 ish for 13.5 galls HIGHWAY thats worse than I was getting backroads...erg
Old Jan 25, 2009 | 08:10 PM
gnictry's Avatar
I changed pass o2 so now have two new bosch o2 sensors for front (back tuned out)
Tires at 36psi warm
Filter clean...
Not sure what else still getting 16mpg HIGHWAY
Old Jan 25, 2009 | 08:34 PM
FICINJECTORS's Avatar
Try ohm testing your injectors.
http://www.youtube.com/watch?v=_g8PdrT0MCU
Old Jan 26, 2009 | 05:41 PM
gnictry's Avatar
wires just unplug?
Old Jan 28, 2009 | 01:18 PM
gnictry's Avatar
tested them cold and all read 12.2...good or bad?
Old Jan 28, 2009 | 02:29 PM
not the best, but as long as they're not reading with wide swings between them youre okay there.
Try testing them hot.
Old Jan 28, 2009 | 07:16 PM
gnictry's Avatar
13.6 at 190 temp
Old Jan 29, 2009 | 06:42 AM
coils on the injectors sound like theyre good.
Only thing left I can think of is possibly a stuck injector, easiest way to test this is to hook up a fuel pressure gauge, turn the key on to prime the system, and then turn it off, and see if it holds.
Or possibly vacuum leaks
Old Jan 29, 2009 | 09:52 AM
gnictry's Avatar
were and how much is a fuel pres gauge to test with?
Old Jan 29, 2009 | 10:00 AM
auto zone has them. make sure you get one with the proper adapter for the gm schraeder valve 20 bucks for a cheepie but it will work
Old Jan 29, 2009 | 11:55 AM
Frost's Avatar
I don't buy that the car runs great with a stuck injector though. It makes power and drives well; the fuel trimming is very tight. If an injector were hung you'd see the trimming for that bank go nuts. Vacuum leaks would show up too as the IAC attempted to compensate for the extra airflow.
