Quick question - Injector Placement
Old Jan 10, 2009 | 03:33 PM
jermstyle's Avatar
Default Quick question - Injector Placement
I just flowed my injectors and 3 flow a bit less than the others. Where would it be best to place the least flowing injectors?
Old Jan 10, 2009 | 03:54 PM
405HP_Z06's Avatar
Highest flowing - 5
Next highest - 7
No particular order for the rest.
Old Jan 10, 2009 | 06:54 PM
jermstyle's Avatar
Why that order?
I didn't get the reply in time so I installed the best flowing in 7-8 and then the least flowing in 1-2 and the others in between.
Old Jan 10, 2009 | 07:22 PM
405HP_Z06's Avatar
Because 5 and 7 run the leanest. Most fuel related engine failures occur in 5 or 7 first.
Old Jan 10, 2009 | 07:40 PM
jermstyle's Avatar
OK, well 7 and 5 have better flowing injectors with the least flowing in 1-2. I also calculated my IFR based on my least flowing injector. Should this work or do I need to re-config something?
Old Jan 10, 2009 | 07:43 PM
405HP_Z06's Avatar
You will be fine, go with it.
