Fast (2) Longer bolts??
Old Jan 12, 2009 | 05:23 PM
03 BUSA's Avatar
Default Fast (2) Longer bolts??
Just got my Fast 92 and most of the bolts were in the intake with a nut on the underside. 2 were left out and in the packaging. They seem to be longer than the rest. Is it me or is there a reason that the fast's use 2 longer mounting bolts? Also, were exactly would the 2 longer bolts go, what holes? I want to make sure it is correct. Tried a search, thanks for the help.
Old Jan 12, 2009 | 08:47 PM
405HP_Z06's Avatar
According to the instructions for the FAST 92, all of the manifold to head bolts should be the same length (110mm).
From the instructions:
Old Jan 12, 2009 | 09:49 PM
03 BUSA's Avatar
I seen that and also talked with Fast tech. They said the same thing. I think that the mold is lower on 2 areas of the intake making it seem like the bolts are longer. Not really the case. I am just attention to detail and noticed a good 1/8th difference. The head holes are blind so no worries. Thanks for the response.
Old Jan 12, 2009 | 10:14 PM
405HP_Z06's Avatar
I didn't notice any length differences on my FAST 90, but the top is different on the 92 so I'm sure your correct.
Old Jan 19, 2009 | 08:54 PM
ricernomore's Avatar
there are spots on the intake lower then others. I thought the same thing until I read the packet that comes with it. They are the same, but the holes are not even all the way around
