worth it to move FP regulator to the rails?
Originally, I wanted to go with a dual pump setup, but that is way overkill for what i have planned in the near future... so with that i have a few questions. I am going to be installing a fuel pressure gauge, and while i'm at it, was thinking of upgrading all the plumbing by adding rails, a return line, and moving the regulator up front to keep pressure steady.
So my question is, would it be worth it to upgrade? I would need to go shopping anyway to get the correct fitting to mount my gauge to the stock rails, but should i just upgrade the lines/rails and add a regulator while i am at it? Would this upgrade give me any safety over my current setup? Or should i just leave everything stock as is and just add in the gauge? 550 rwhp max is what i'm working with right now... thanks guys!
The advantage is that you can also boost reference your pressure to get more fuel under boost without having to increase your injector size. You would have to retune if you did this.
I have complete kits if you are interested.
That was my car...your results may vary.
Really, I was just curious if it would help with my fuel pressure fluctuations, so I just threw money at the problem, leading me to my final point - it isn't cheap to do something like this. You'll most likely be looking at new rails, braided lines, and all the necessary fittings...it adds up ($$$$) FAST.
I got the hold downs and I got everything on today. I don't have fuel pressure now. I turn the key, I hear some "priming" the gauge moves a tad and drops down to zero, I crank it and nothing happens. The passenger side rails get the feed, goes around the back and up the driver side where the regulator is mounted. The bottom port goes to the return. I removed the stock fuel pressure regulator in the tank.
I used the evap as the return. All I had to do was remove that part and run the line there correct? Or am I missing something, well obviously I am, there's no fuel pressure.
walbro 255 pump
fuel rails
boost referenced regulator
I removed the stock fpr, took the extra hose off from the feed and evap ran the feed to the passenger side, crossovers in the rear, regulator is mounted on the rail. The boost is referenced from the housing on the turbo. The bottom port goes to the evap line. I changed the IFR and offsets to reflect the boost ref reg. I'll post up a pic in a minute
I'm learning about tuning while my cars sitting. Its all about the scanning is what I'm gathering and having a smooth ve table. 2 bar SD right now, I drove it around and had some excessive blowby thats why I got the cans. Hopefully that fixes it and I don't need a new motor right away. I also have some meth and 2 step that will be getting some action eventually.
http://www.geocities.com/formulapower2/fuelpump.html
This is the part that I was paying attention to:
Now you need to disconnect the fuel lines. There are four lines that run to the pump as you can see in the picture. The feed and return lines have the squeeze connectors on them and the vapor lines have rubber connectors. I disconnected the vapors lines first and then worked on the feed and return lines. You should be able to get your fingers in to squeeze the disconnects. It's best to work one at a time. If you can't get your fingers in try to depress them with a screw driver. You'll hear the connectors click when the release. The just pull and the should come free. Once you've got all the line disconnected, pull the pump assembly up and forward (you may have to pull a little on the longer line to get it out of the hole. Once all the lines are out of the hole slowly rotate the assembly clock wise till the lines are pointing toward the front of the car. Now pull up and tilt the assembly toward the drivers side of the car so it will come out of the hole. BE VERY CARFUL when pulling the pump assembly out so you don’t mess anything up. You will be able to tell which way you need to bring it out when you see it.
Doesn't exactly tell you which is the return and which is the feed, but it might make it easier to figure out which 2 out of the 4 are the ones you need to be looking at.
https://ls1tech.com/forums/fueling-i...size-plug.html
That's the correct fitting to use, but people have done it with a pipe plug as well with no issues. I just figured that since I went that far, I might as well just order another part and finish what I started. I'm pretty retarded like that...
Like meentss02 said, there must be something you didnt cap off that is letting fuel back in the tank... at least thats what it sounds like
Also did yall remove your canisters?
As for my canister...it is still in there. I just put a rubber hose with a plastic vent on top of the tank to let the fumes become one with nature.
If I get time this week I'll take a peek inside the tank and see what has to be done and hopefully cap that T.
