1968 Lq9 camaro swap EFI Tank Question
I am doing a Lq9 swap..with a Magnachager...engine and trans is in, going to mount the magnacharger soon...the car is going to be a road race car so it is gutted.....here is my question: can use a high pressure fuel cell in the trunk ? If I dont care about where the gas tank is located, I dont need to go with a Rick's Customs Tank......Will a regular Jegs...I am on a budget fuel cell with the sender work just fine? Any thoughts on this....I am on a budget...
the car should make approx. 500 rwhp.....so will the sender work or will i have to go with a bigger one? Thanks.
http://store.summitracing.com/partde...5&autoview=sku
do you have a suggestion on a fuel pump?
LS1TECH Sponsor
The 0-90 ohm sender will work w/ your stock gauge.
The tank only has a -8 outlet, which is small for a large pump but for a under 400hp setup should be OK. For big pumps you should use a -10 inlet, so this may be something to look for.
You likely need a -8 supply & -6 return line for your car.
I would look into Magnafuel pumps, they have good quality pumps for a reasonable price. Look at an appropriately sized pump for your current & future needs. don't go cheap & definitely do not just buy the biggest one either as this causes many problems as well.
http://www.nastyperformance.com a vendor here sells these pumps so you may want to look him up.
