Fuelab variable speed controller wiring
Old Feb 2, 2009 | 06:01 PM
qwiketz's Avatar
Default Fuelab variable speed controller wiring
Hi guys. I'm looking at the fuelab pumps. I was wondering how you guys are wiring them up. I would like to run it slow when cruising around and crank it up when I'm into boost. I saw manual switches used on the instructions but I'd rather have something automatic such as a hobbs type switch. I just don't know how to make it work. Anyone have any experience with this?
Old Apr 21, 2014 | 08:04 PM
tictakman's Avatar
Im bringing this back up from the dead because I too am interested in how people are wiring the variable speed on the Fuelab pump.
Has anyone just run it full speed 24/?
If you did the 2 speed, how did you wire it to come on?
I was going to use a pressure hobb switch. Once it hit a low psi in boost it would open the circuit and go full speed.
Zak
Old Apr 21, 2014 | 10:13 PM
cmac06's Avatar
Just use the electronic pressure regulator they sell, and she it as it was designed to be used.
Old Apr 22, 2014 | 06:46 AM
tictakman's Avatar
I saw that but I already have my regulator setup so I was trying to avoid that.
Old Apr 22, 2014 | 06:56 AM
Old Geezer's Avatar
1-800-fuel lab???????
Old Apr 23, 2014 | 07:22 PM
tictakman's Avatar
Nice constructive post. That isn't actually the number for anyone that is looking for actual good information on ls1tech...
On another note, Ive order a pressure hobbs switch and will see how the setup works.
Old Apr 24, 2014 | 06:59 AM
Old Geezer's Avatar
Default Weird..
Instead of making a simple fone call, and asking the folks that make the product, you choose to go fishing...
Old Apr 24, 2014 | 07:11 PM
tictakman's Avatar
Listen, the whole idea was to find out what others have done in the past that are members of LS1tech since its a forum. I could PHONE fuelab and ask but they will promote their product obviously. I went fishing by asking LS1tech and it looks like I got some guppie biting...
Old Apr 24, 2014 | 10:00 PM
cmac06's Avatar
A Hobbs switch or some other switch to ground at WOT would do it if you don't require continuously variable operation. I ran using the regulator because it was a ground up fuel system.
