what is a boostapump?
Old Feb 13, 2009 | 12:23 AM
whitew01ws6's Avatar
Default what is a boostapump?
iam puttin a sts kit on my car and a freind of mine asked if i would be interested in buying his boostapump from the sts kit he bought. he said it should up my fuel pressue so the stock injectors will be able to push out more.
need help what will the boostapump do for me? or do in general
Old Feb 13, 2009 | 12:33 AM
BobDoLe's Avatar
basically it overjuices your fuel pump so that it increases the fuel pressure.
it overworks your fuel pump.
personally, i'd rather upgrade the in-tank fuel pump, but guys have been using this boostapump forever.
Old Feb 13, 2009 | 02:26 PM
so how would this benifit me with a stock fuel system? with boost
Old Feb 13, 2009 | 02:45 PM
MMMZ/28's Avatar
Did you not read what he put? It over works your fuel pump so it pushes more fuel? Your motor will use more fuel when the boost is on.
Old Mar 1, 2009 | 06:03 PM
EPP's Avatar
EPP
Don't use the boost a pump, go with a Walbro 255 litre in tank fuel pump and add 42lb or 60lb fuel injectors and get the car tuned. Bob
Old Mar 2, 2009 | 12:54 AM
tording99Z28's Avatar
What bob said. The boost a pump is the workaround. Yes it does work most times but is not the best way to do it. Get a bigger intank pump and bigger injectors and get it TUNED!!!
