trap door for access hole
Old Feb 15, 2009 | 08:28 PM
98Camarod's Avatar
right, if you could find it bigger then you got it. Someone already mentioned it, I think a fuse box cover would work well.
Old Feb 15, 2009 | 09:42 PM
Disturbed Bird's Avatar
y wouldnt it work the moroso door out side diameter is 8.125"x8.125" the inside is 6"x6".
you only need to cut a 7"x7" hole. so it should be good to use
Old Feb 16, 2009 | 10:18 AM
myfast70's Avatar
The Moroso trap door should work just fine. The trap door I cut was 5" x 5 3/4". I just got a piece of stainless sheetmetal and made it about 3/4" longer on all sides and held it down with 4-40 button head screws and sealed it with Ultra Black. I also painted it the same as the body color to match and put a dimple in it to match the factory seam.
I used a Dremel with a fiberglass cut-off wheel (just 1 needed) and took my time making the cut. It took about 3-4 minutes to complete the cut and pop the panel out. It is a bit tight but worked out real well.
Old Feb 17, 2009 | 12:16 PM
Speed_Freak6's Avatar
I have to change mine out soon for my setup. I have been real nervous about doing the access door because I want to keep my car as original as possible. I know GM has put door on other vehicles ie: Impala
Has anyone ever noticed any problems with the metal flexing after a while or any other issues with their setup?
Sticky worthy?
Old Feb 17, 2009 | 12:35 PM
nemss1's Avatar
no flexing probs that ive noticed. small panel cut out wouldnt affect structurability much if any
Old Feb 18, 2009 | 09:58 AM
myfast70's Avatar
No problems what so ever with mine. The door does not vibrate or allow any more noise than before. I made sure to seal it with silicone to prevent any fumes from coming thru.
Old Feb 18, 2009 | 10:14 AM
mebuildit's Avatar
I've used one similar to these. http://secure.mckinneycorp.com/AMAZI...c=M%2D4795&eq=
