who DD with a fuel regulator mounted at the rails?
I am in the process of adding a new feed line with a new fuel regulator and using the stock feed line as the return, but I want to know if I will have problems with "heating the fuel" and returning it to the tank.. I dont drive the car EVERY day, but don't want any problems if I chose to do so!
any help or insight is greatly appreciated!
i assume that you guys aren't running EVAP either? I still have mine... so i wonder if that would help anything or not
And you are correct in your assumption - I actually use the EVAP hard line for the return, and I have the tank vented on the top of the tank.
