boost dependent FPR- return system
Old Feb 25, 2009 | 02:52 PM
TurboZ28408's Avatar
Default boost dependent FPR- return system
i saw this picture on another website, is it possible to route my fuel pressure regulator in this fashion where the stock distribution block is for the 98 camaro ?
Old Feb 25, 2009 | 03:32 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
You could, but pressure control will not be accurate unless the regulator is mounted at the rail.
A rear mount regulator is not a good way to control pressure.
Old Feb 25, 2009 | 11:06 PM
pmbmax's Avatar
X2.....
Old Feb 26, 2009 | 07:26 AM
ss1's Avatar
ss1
Apparently a 2-inlet regulator will allow one of the inlets to act as an outlet if used as pictured? Is that the purpose of mounting that way? Is it any more or less accurate when mounted this way as compared to usint the factory T and in-tank regulator?
Old Feb 26, 2009 | 05:13 PM
LS1TECH Sponsor
The 2 ports are just a pass through.
The regulator functions the same as stock in this situation & only gives the benefit of adjustability over stock.
