Question about using stock feed as return
I am thinking about using the stock feed line as a return. If I do that, do I need to remove the stock filter and use some fittings and a line to replace it, or can I just put a new filter in there so it doesn't backwash all the junk out of the current one? I'm not sure if the stock filter is directional, if it can be turned around, or anything like that, and I'm not at home to look at it at the moment.
Thanks in advance for any help.
Using the stock return line was too small and it wouldnt regulate. As soon as I added the -8 (or maybe -6, I dont remember) I could adjust my pressure, still using the stock feed line.
ill be going to a braided -8an feed, now how are you guys attaching the big an fitting to the sending unit?
at my work we sell rolls of the factory plastic 3/8 fuel line i was thinking of running that instead of useing the factory metal for return to save a lb or 2
my car is a 98 with a plastic tank swapped in it from the previous owner so im not sure whats all on the insides
heres my crappy pic to make sure im understanding 100%
