LSX Injector question
I have LS6 injectors installed in an LS6 transplant into a '00 WS6. I can't get the damn thing to start. A slight rumble for a second, then it just cranks as if no fuel or spark. A noid on the #1 injector shows firing, and there is spark as well. Thoughts? I'm reaching for straws here.
-JS
-JS
You have fuel pressure at the lines? Was the PCM reflashed? Check the plugs to see if you have fuel on them. Check all your sensor wires. Could be lots of things you have to eliminate to basics.
Nate
Nate
Nate
Nate
-JS
