Startup problem
Old May 31, 2009 | 08:21 AM
52172's Avatar
Default Startup problem
Having a problem starting the car. Once I get her started seems to run fine. I have an A-1000 with FPR and return. Seems to not get fuel. Once running she runs fine is it the check valve in the pump letting all the gas run back into the tank after shutting her down? If the FPR was bad wouldn't she run poorly while running especially at upper rpm's? I am pretty sure I need to get a new A-1000? What the best way to pinpoint the problem? Tank is sumped with -10 high pressure fuel line. Thanks
