What size injectors, stock 02?
Old 06-01-2009, 08:06 PM
Slow 346's Avatar
Default What size injectors, stock 02?
What size injectors came stock in a 2002 Z28?
Old 06-01-2009, 08:37 PM
JASON11WS6's Avatar
26#ers
Old 06-01-2009, 09:23 PM
FICINJECTORS's Avatar
the 2002 camaro uses a Bosch 3 part # 0280155931 which flows 28lbs with the 58Psi rail pressure. The injector is rated at 24lbs at 43.5psi
only 99-2000 use the smaller 26 all other LS1's use the larger ones
Quick Reply: What size injectors, stock 02?
