injector swap
Old Jun 2, 2009 | 10:04 AM
JASON11WS6's Avatar
Default injector swap
I'm about to swap in some 60# Motrons. I have my fuel maps ready to go to install them but have one last question. Can I use the o-rings on the base of my stock injectors for these new injectors? They came with the o-rings on the top fuel rail side but not them bottom manifold side.
Old Jun 3, 2009 | 06:43 AM
JASON11WS6's Avatar
The answer to my question is yes. But, if you try and take the o rings of your stock injector with a radiator hook you have to buy new ones anyway. The base on the stock ones is pretty wide so I had to really stretch it to get it over the base and it snapped. So I need to find a new set, hopefully I can find a dealer in the area with a set so I can finally get these thing going.
Old Jun 3, 2009 | 07:15 AM
koolaid_kid's Avatar
You should be able to pick up a set at your local auto parts store.
Old Jun 3, 2009 | 07:27 AM
JASON11WS6's Avatar
I tried the other day to get a jump on it and they said no... I tried two different places. I think they both suck for real parts though.
Old Jun 3, 2009 | 09:05 AM
69LT1Bird's Avatar
The plastic cap/retainer on the bottom comes off so you can easily change the 0-ring without over stretching it.
Old Jun 3, 2009 | 09:27 AM
JASON11WS6's Avatar
I wish I new that yesterday. Shoudl I try and put those caps on the new injectors or no?
Old Jun 3, 2009 | 09:28 AM
JASON11WS6's Avatar
Also, how do you take them off? Do they twist off or do you just pull on them?
Old Jun 3, 2009 | 10:06 AM
69LT1Bird's Avatar
gently pry them off.
Take one off and see if it fits the new injector, mine have always came with them.
Old Jun 3, 2009 | 10:28 AM
I got my last set at Autozone.
Old Jun 3, 2009 | 10:38 AM
JASON11WS6's Avatar
Autozone told me that had nothing like that. I just called Napa which is right down the block (totally forgot they were there) and they have them for $2 each. I guess I just need one since I only snapped one now that I know that piece comes off. Any one know how to take it off?
