Using Techron to clean injectors?
Old Nov 8, 2003 | 05:19 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Using Techron to clean injectors?
I got a bottle of GM injector cleaner, does it help?
I am using it on my 99 Tahoe with 126K miles on it.
Old Nov 8, 2003 | 06:53 PM
felton316's Avatar
All the guys at the diesel shop I work at, swear by that stuff. They buy that stuff by the case load.
Old Nov 10, 2003 | 09:39 AM
robertbartsch's Avatar
I recently used it in my wife's Benz with 100K miles....added a double batch for about six tank fulls of gas....by the sixth load the difference was amazing... car runs smoth as glass now....
One treatment alone will not do much ...you need to do several tank fulls to really clean it out...but it works!!!
Old Nov 10, 2003 | 11:15 AM
LS1Tech Co-Founder
The bottle was $12, and it says to run the tank to almost empty, add it, and then add up to 20 gallons of gas... I'm not comfortable doing two bottles.
I'll try it pretty soon, I'm at 1/2 tank right now.
Old Nov 10, 2003 | 12:21 PM
Cheatin' Chad's Avatar
The techron additive is the same detergent package Chevron puts in their gasoline.
I use Redline fuel system cleaner . I have had good results with it.
Old Nov 10, 2003 | 05:28 PM
I just bought a bottle of fuel system cleaner for $9.99 that is titiled, "Guaranteed to Pass Emmissions"
I have not used it yet, however. It's directions are very similar to the bottle you bought. I'll check the contents tonight.
The stuff I have been using for a long time is cheap at $3.00 per bottle; it is sold at Martha's place (K-Mart) and is mostly methonal based... anyway, after several tank fulls, it cleans the fuel system really well....I've used it for years....great stuff...
Old Nov 10, 2003 | 06:33 PM
Sport Truck's Avatar
Default Techron/ Redline
Techron is a awesome injector cleaner and it will remove valve coke.
MB techs have been using this forever, it and Redline are one of the few things that actually work(do what they say it will).
Redline makes a product called 85 plus it is by far the best injector cleaner, pre chamber, and combustion chamber cleaner you can put in a deisel!!
Another one beleive it or not is one from Auto Zone TL-3 is good on injectors, if a label says it will work on the BMW"s and MB's it good enough for any thing else.
Lubro moly makes a Ventel Sauber injector cleaner that works real good, they also make a deisel purge for high milage cars and trucks that rocks. Deisel Purge does works great on GM deisel that have not been cleaned in a while, pour it in a fuel filter fire it up and rev it couple of times. Just don't do it a garage with out fresh air mask, it will pour the smoke! You can also rig it up run it straight, the can as a fuel tank with a return and it does wonders.
Old Nov 10, 2003 | 07:52 PM
2002SilverWS-6's Avatar
Do you only get Techron from GM or can you buy it aftermarket?
Old Nov 11, 2003 | 01:04 AM
You can buy Techron at Chevron gas stations, Hell even A zone stocks it.
Old Nov 11, 2003 | 09:12 AM
LS1Tech Co-Founder
How many treatments should I shoot for?
I'm mainly doing this because I'm doing a 125K mile tuneup on the truck, and this was on my list, but the idle is not the smoothest.
Old Nov 11, 2003 | 11:21 AM
quik 99SS's Avatar
Techron is actually the same stuff that is in the GM fuel system detergent cleaner. I do one bottle every other oil change. The SS runs smooth as glass.
Old Nov 12, 2003 | 09:13 PM
StalkerLS1's Avatar
Just curious if the Fuel already has additives to keep the injectors / fuel system clean then whats the point of adding more?
Old Nov 12, 2003 | 10:50 PM
Yes most fuels already have additives to keep injectors clean. Sometimes it's not enough to keep things clean under certain conditions.
PSJ: I would run it through once or twice.I have always used a full tank of untreated gas in between fuel systems cleaners.
Try to avoid solvent based cleaners. Techron and Redline are detergent based. If you don't have Redline available in your immediate area the local BMW (one on every corner in Chicago right?) dealership should carry it in 6oz sizes. I can get the BMW part number if you need it.
If that doesn't do it for you there are treatments plumbed directly into the fuel rail which usually work pretty well.
Finally,If you want to get serious send them off to a company like JET that will vibratory and/or chemically clean and flowtest your injectors.
Old Nov 13, 2003 | 09:27 PM
2001 Pewter WS6's Avatar
Restricted User
How in the world do you have time to put 125,000 on a 1999 truck and have time for 12,000+ posts???
