Flex Injector help for 5.3 to ls1 intake swap
I am running a 2006 L59 engine in my 46 coupe. For a few reasons I am swapping over to the LS1 intake. I bought an intake and rails so I can complete the swap.
I know my truck injectors won't fit in the LS1 rail. Simple solution would be get my ls1 injectors re-manned and run them. However it is my understanding that the Flex fuel injectors are 34#. I'm not sure if there is anything else special about them to run E85.
So my question is, what car style injectors can I use on my LS1 fuel rail that will allow me to continue using the flex fuel capability?
Thanks in advance!
Mark
Thanks in advance!
Mark
LS1TECH Sponsor
You could send me your computer for a reflash and get a set of the 24508208 injectors from us. We have them right now for $25/each. They are rated at 36lb/hr. You would also need the adapter ends for the injedtors as they have the old style EV1 plugs.
Hope that helps.
Hope that helps.
