Punctured Fuel Line HELP!
Since the line is under no certain pressure I just went to my auto parts store and got some of that mending putty and formed a good seal around the hole. Seems to be holding just fine. Hope it holds!
Thanks!
Thanks!
Unfortunately due to the location of the hole I cannot fit a piece of tube over it. It is located right next to the "T" junction. If I did put a piece over it, the clamp would be right on the hole. Also, there would be no way to replace the rubber line that is already on the plastic "T" junction. I left the cutout and carpet out of the car so I'll keep an eye on it and check for leaks every chance I get. I also always have a fire extinguisher in the car.
Here is a better pic.
