Sealing an oringed Aeromotive FPR?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
any tricks or recommendations on sealing an aeromotive FPR that uses orings?
new reg, new fittings with orings, but getting some bleed from the seals/seats/orings.
thanks
thanks
I'd look at the diameter of the o'ring being too small. [Both the ring material thickness, and the od of the ring]. Even if the ring material is correct, and the overall diameter of the ring is too small, it'll be stretched too much, reducing the material od, = no seal.
I'd also look at the possibility of the fitting bottoming out in the reg, B4 the o'ring is compressed.
thanks Chuck.
fittings w/orings were purchased from aeromotive, i hope they sent the right ones, although it wouldnt be the first time an error was made.
to clarify:
its not leaking to the point of seeing any fuel, you can see where dust/road grime is collecting/sticking to the fpr around the fitting.
on occassion i do smell fuel tho once i park it in the garage, but not sure if thats just the braided line from rail to fpr venting like others have mentioned.
thanks mang.
to clarify:
thanks mang.
