80lb injectors 114%, fuel system upgrade options
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Ok I'm confused. Why is it set at 72psi base pressure? I thought its suppose to be 58-60? So with 26psi of boost the fuel pressure gets to 98?
Please explain.....
So are you going to try a smaller crank pulley, because you have an ATI super pulley right? I think they only make two sizes of those.
Please explain.....
The pressure stuff, Jim will have to answer because I don't mess with that. I let him set it up when he's tuning it.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I wish there was an easier way to bring down the boost.
