Wow, thats a trip. Remember though that any electric motor will create a small amount of feedback otherwise known as A/C ripple. Someone smarter then me could probably tell you what type of capacitor would solve your problems but hooking it to the battery is probably a more convenient idea. The battery will work as a filter, negating the feedback. I'd still be better for a cap of the correct mf to be used as it would probably make the pump run cooler. You see this stuff all the time with a/c voltage air conditioning systems. The compressor creates a feedback voltage slightly behind phase of the voltage source and the fan motor creates a voltage phase slightly ahead of the incoming voltage. These out of phase electrical currents create heat since they act against the source voltage. Capacitors help to prevent this interference from making the motors run hot and allow them to use less electricity. D/C stuff is affected by this as well but in your case, its not just affecting the pump, the errant voltage is affecting the PCM as well from the sound of it. On another note, I wonder if maybe just a diode between the alt. and the pump feed would solve the problem as well? That would also prevent any feedback from entering the system.
