Ok I need a fuel system that wont vapor lock?
Ok I been fighting vapor lock for a month now... I've heat wraped everything fuel cell and any line close to a heat source... Im running a magnafuel pump and boost ref reglator alum sumped tank its a nasty performance system.. I;m ready to change it up because it is not streetable..It will run for maybe an hour an vapor lock.... So what pump are you running on the street that works??? I'm ready to drive the car some!!!! I'm tired of this vapor lock...Please help me with a streetable setup.. If I have to go back to the stock tank that's fine...
Thanks
Thanks
